To minimize inductances, all wires connecting to the grid and plate pins as well as ground wires should be as short as possible.
Oscillations problem help
Originally posted by catalin gramada... why 1M grid leak resistor is need it as time 47k input is shunted to ground ...
Useful link 1)
https://robrobinette.com/Amp_Stuff.htmIt's All Over Now
1. The input is not floating. It will be shunted to ground when not in use. 2.Even by an open contact by accident the current is well limited to not endanger the tube. 3. Is not clear how setting in grid a resistor to the ground you get a higher impedance relative to the source as we are talking about a guitar pickup impedance series with 47k of the stopper relative to impedance of the grid which is theoretical infinite...This is a must for sources which contains DC components and should be isolated by a cap...then it need a grid reference for the tube... not my case"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View Post1. The input is not floating. It will be shunted to ground when not in use. 2.Even by an open contact by accident the current is well limited to not endanger the tube. 3. Is not clear how setting in grid a resistor to the ground you get a higher impedance relative to the source as we are talking about a guitar pickup impedance series with 47k of the stopper relative to impedance of the grid which is theoretical infinite.
And sometimes switching jacks fail.
What's the problem with adding it?
I would connect the 47k grid stopper directly to the socket pin.- Own Opinions Only -
Originally posted by vintagekiki View Post2. How tube get bias voltage?Last edited by catalin gramada; 07-23-2021, 06:24 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Tube current is limited by plate resistor and the grid leak resistor is only required if there is no other DC path to ground.- Own Opinions Only -
I posted my layout, just indicate me ...: the current path which create a ground loop from point A to point B because I don't see it.Last edited by catalin gramada; 07-23-2021, 06:58 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by HelmholtzNo personal attacks, please.
1)
How tube get bias voltage when the jack is open and no grid leak resistor. (schematics)
Originally posted by vintagekiki View PostLast edited by catalin gramada; 07-23-2021, 07:48 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
