How to determing parts from schematic (i.e. transformer)
  • How to determing parts from schematic (i.e. transformer)
    Let's say I wanted to build the amp in the attached schematic. How would I figure out a reasonable transformer to use based on the limited information given? Click image for larger version
    Which of the 2 transformers?
      I am specifically looking at the "HV winding" item right now. But yeah, the output transformer has even less info.
        Most necessary info can be found in the tube datasheets.
        OT should have a primary impedance around 8k and be rated for 6W minimum.
        PT has 3 secondaries:
        - 6.3V heater winding for 6V6 and 12AX7. Adding heater currents of 0.45A and 0.3A plus a little safety margin gives a current rating around 1A.
        - The 2x 270V HT winding. The 6V6 has an idle current of 48mA, add ~1mA for the 12AX7. With fullwave rectification AC current roughly equals or slightly exceeds DC current, so the HT winding should be rated for 60mA minimum.
        - The 5V heater winding for the 5Y3 should be rated for 2A.
          I always then browse the Hammond catalogue for the best match. In this example the Fender Champ 5C1/5E1/5F1 has the same tube arrangement, so is easy to find.
