Hammond 1650 impedance selector
  • Hammond 1650 impedance selector
    Hi all,
    I have tried to do a search on the old ampage forums but I seem to get only software errors at the moment, so here I am with a question that's probably already be answered a million times: is there a way I could hook up a Hammond 1650 OT so that I could use a selector to switch impedance? I know tubesandmore sells something like that but I live in Europe and don't feel like paying loads on shipping for something that maybe can be done with a 3 positions 3 poles rotary switch or something like that.
    Has anyone done this before and cares to share some schems?
    Thanks in advance
    Maurizio
    Hi Maurizio,
    Have a look at this:
    http://dst-engineering.com/TN.php?n=OTWiring
    All you need is a solid three position rotary switch with 3 levels. I'm sure you will get one also in our old Europe .
    Ciao,
    Joachim
    Live long and prosper
      Thanks Joachim, With a bit of patience I was coming up to pretty much the same solution. What I can't understand is why Hammond sticks with these odd output configuration but hey oh...as long as it works in the end.
      Cheers
        Maurizio,
        My guess is that Hammond wants to use reasonably-sized secondary wire to keep transformer size and cost down, and yet maintain their full-power specifications into a 4-ohm load. According to Kevin O'Connor, Hammond had a line of output transformers with conventional 4-8-16 ohm secondaries, but I've spoken to three people at Hammond and none could confirm this, or find the part numbers in a computer search - maybe these are only available in Canada.
        I agree - it can be a real PITA to replace a 4-8-16 OT with a Hammond.
        Ray
          Check out the AX84 October
          http://users3.ev1.net/%7Ecliffchappe...005.09.28.html
          It uses a 1650F and a impedance switch, and the schematic has a wiring diagram.
          Jon
