dovetail jigs.. argh!!
  • dovetail jigs.. argh!!
    hi, I really need help here. The basics of a simple router dovetail jig are easily found on www, clips etc.. but its still completely puzzling me!
    Ive just got a simple dewalt dovetail jig, checking that at 12" width by 1" max stock thickness I can dovetail, well, 9" wide by 3/4" thick pine together (for a std combo cab joint). If only it was this simple..
    the template when placed over the 2 set wood pieces can clearly only go 5mm into the horizontal piece.. so I can't make a dovetail?!?
    also can s'one clear this up: the bush that attatches to the router seem to be made so that it rubs/ is in flush contact with the metal template as the bush seems ONLY to slide in/out of the grooves like so, ie I presume this is for safety so one cannot lift the router & bit up into the metal (again I presume- this is highly dangerous?). But with bush attatched, the router still needs the thin placcy baseplate or A) the bush screws will jar slightly and B) for a proper steady router. But this placcy plate leaves the bush recessed slightly.. meaning it now 'sticks'/ doesn't slide in/out the grooves?!?
    Also how do I jnow what depth to set the bit to?
    Im completely baffled.. sorry for long post but help, please! thx capt
    The Captain;77955]hi, I really need help here. The basics of a simple router dovetail jig are easily found on www, clips etc.. but its still completely puzzling me!
    Sounds like a blind dovetail jig for drawer fronts, the pins don't go all the way through so you cant see them from the front.
    You kinda lost me in this paragraph
    Generally you have to make some test pieces and adjust the bit depth for a tight fitting dovetail
    Sorry I couldn't be of more help.
      thanks for trying to help- so Ive bought a 'blind' dovetail jig then which is totally useless for cabinets..? if the thing was sold as a 'blind dt jig' then I'd have bloomin known..
      Ive phoned deWalt/ B&D re the bush, but nearly impossible to explain.. in short: bush into template, my Q A) are these two designed to work flush against each other? (if so the screws pretrude slightly, so they jarr-??) or
      B) should there be a tiny gap between the two? (if so then the bush jams in the template as the bush centre in slightly convex-??)
      thoughrally confused me. Capt
        so how the f*k are std dovetails made then??? (apart from by hand, nuts to that!).
        if I buy a machine for making a car, I expect a car to pop out. Not a van truck or a boat. a car. argh bllx!!
          You can make a guitar cab with blind dovetails.They arent as ornamental but they are quite strong.It is very frustrating as well as uses a lot of scrap pieces till you get it just right.I've stopped using my "dovetail jig" for the router and now use my table saw with a dado blade,it is still very tedious,but not as bad as the router set-up.I havent looked at the jig I have for the router in quite a few years,but I believe to make a regular dovetail you need to use a "straight" bit instead of the conical shaped "dovetail" bit.The directions that come with the jig should tell you if you can make a standard joint.
            Just went and had a look at my jig,I think what you want is a "box joint jig".
              +1 on the table saw suggestion. I make box joints on the table saw and they turn out great. If you are going with a natural wood finish, then dovetails might be a nice detail. But if you're just gonna cover the cab in tolex, go with 3/4" box joints and move on with life. Box joints are strong as all getout. I sit on my cabs all the time, and I am 6'2" and about 240lbs. They are rock solid.
              In the future I invented time travel.
                hi Mr. Stokes.. yes I think a box joint jig is what I really need- thing is I did try and find such a beastie, but it seems there just aren't any fs here at all, well certainly not affordable jigs like my £40 odd deWalt ($80 US). Ideally a tablesaw/ box jig sure is the best- but your talking well over £100 just for the saw, besides I dont have room for a tablesaw, plus I have a decent router here..
                decorative joints is not what I need as I'll always tweed cover a cabinet: all I want is just a strong well made joint, without any cleats/ bracing which just get in the way of the baffle.
                I wonder what happens if I used a straight bit with this template (if I can work out the f*&kg bush into template nonsense), so routering one piece at a time, both in the jig's vertical position..? I'd need to allow for exactly the correct offset between pieces obviously.. but on paper thats a good sized box joint right there, is it not?
                  yes, but as I said box joint jig is out of the Q.. tablesaw + jig = £200/ $400 min? just to make a couple of cabs?
