Interesting cab construction article in Audio Xpress
  • Interesting cab construction article in Audio Xpress
    The current newstand issue of Audio Xpress http://www.audioxpress.com/magsdirx/ax/index.htm has an interesting construction article on making a different kind of 2 x 10" cab. The two speakers are set at 20 degrees from each other, facing slightly inward and cross-firing. But their baffles are set at a 15 degree angle pointing slightly upward. The goal is to have better dispersion and reduce comb-filtering. Interesting design and idea.
