Hello
I'm trying to decide what the best option is for me in building my 2x12 combo. I've got a Rivera K55 head which I simply love that I wanna put in a 2x12 combo. I've gotta buy tube retainers for the extra vibrations,
I have a few questions for the builders out here:
1. Should I go with a Twin kinda config where one of the speakers is a bit higher positioned that the other, or should I go with an inline configuration where both speakers are the same height?
What's the difference soundwise?
2. If I go with the twin config will I be able to hear myself better as one of the speakers stays a bit higher? If so, what's the trade off?
3. The other thing is I want to angle and front baffle a bit so that the speakers are pointing up a bit so I can hear myself decently when playing small stages and such. What's the best angle for this for best results?
How do you mount the front baffle in an angle and how do you cut the bottom part of the front baffle so that it's flush with the bottom of the cab at the joint?
Thanks
Thanks
