Hi all. Got the day off, so I'd thought I'd share some of my questionable knowledge.![Wink](https://music-electronics-forum.com/core/images/smilies/wink.png)
To get a cabinet grade finish here is my process. Start with belt, or palm sanding, 60 grit. Then hand sand, 60 grit, everything. Vacuum, or dust off. Put paint thinner on all surfaces, looking for cross-grain scratches. Re-sand if necessary. As always, sand with the grain. Next using a palm sander, 100 grit. Repeat all steps. Dry thoroughly. Next, wet all surface with water. The harder the wood, the wetter you get it. This raises the grain. (Some finishers add salt or use a brine, but I haven't seen it to make a difference.) Dry thoroughly. Re-sand, 100 grit, by hand, sanding block, or random orbit sander. You should be able to skip the thinner by now. Dust off. Repeat at 150/180 grit, wet, sand, dust. Same for 220 grit. Final sanding should be hand sanding, keeping your strokes end to end. You can go as far down the grit line you want. Dust, then clean with tack cloth.
I very rarely stain, but if I do, I use three coats polyurethane, sanding 220 grit between coats, cleaning with tack cloth .
Usually, I apply sanding sealer, sand 220, tack clean, then three coats polyurethane, sanding 220, tack clean between coats.
I do not use water based stains or finishes, they tend to raise the grain. And I use clear gloss polyurethane.
