Casey, a question about your Finger joint jig...To make one of these jigs work correctly the face of the backing board(where the pin is mounted) must be perpendicular to the miter slot slide..(hope that makes sense). How did you install the miter slot side such that it is perpendicular to the backing board? (or do you have the jig mounted on the miter gauge.) Hope that is not a trade secret.
By the way, got to try out the Table saw finger joint jig I got from Sears and it works very good..That is once you get it set up. Set up to adjust the thickness of the fingers is true trial and error. You have to move the whole rig where it is mounted on the miter gauge by hand. My Router jig is set up such that this adjust is by a fine thread screw and sets up really quick.
