I built a 2 x 12 cabinet where the width and height dimensions were exactly the same (i.e. baffle board perfectly square). The speakers were mounted in a diagonal arrangement. I later read that you should avoid having 2 dimensions exactly the same as it can promote strong standing waves that can make the cabinet resonate and sound boomy. The cabinet I built does not have this problem. Maybe because of the diagonal arrangement in which each speaker is not symmetrically located inside the cabinet this doesn't happen? Could it be the space the cones occupy don't allow standing waves to be set up between the walls? Or did I just get lucky with the particualr speakers I used?
I'd like to do the same design but with different speakers now and am wondering if there's any possibility I might get this unwanted resonance with the different speakers. I could make one dimension slightly larger but my present dimensions are ideal for minimizing wood wastage.
I have not been able to find any more information anywhere on this "2 dimensions the same" resonance problem so if anyone here could shed some light on this issue it would be much appreciated.
Thanks,
Greg
Thanks,
Greg
