I've already built a 2x12 open back cab out of pine but before i go any further is there any ways to improve the sound of the pine. I've read that modern pine inst the best since its very soft. I was thinking of sealing the inside with numerous coats of thinned varathane so it soakes in and adds some weight to the cab. Any ideas?
Making Pine More Dense?
Heat and pressure to impregnate it with some sort of hard resin, or use some kiln dried planks of oak or some such. If you really want more dense, go void free birch ply. I tend to like cabinets that don't impart much to tone, and leave it up to the amp and speaker, and the box size and wether it's open backl or sealed.
Originally posted by trevorus View PostHeat and pressure to impregnate it with some sort of hard resin.
Originally posted by trevorus View Post, or use some kiln dried planks of oak or some such. If you really want more dense, go void free birch ply. I tend to like cabinets that don't impart much to tone, and leave it up to the amp and speaker, and the box size and wether it's open backl or sealed.
I would probably listen to the cabinet first and decide then if it needed "improvement". Pine makes a great sounding open back cab as all those BF Fenders will attest. Also, any more reflective material applied to the inside of the cab will increase the amount of high end frequencies escaping the back that will be out of phase with the speaker. Probably making for a DARKER sounding cab rather than a flatter sounding cab. I would be more inclined to harden the OUTSIDE of the box just for durability. I built an antiqued finish three cabinet amp set for a friend from pine and it dents if you look at it hard. But, to address the OP...
Minwax makes a resin product called "Wood hardener" that penetrates soft woods and hardens them considerably to the penetration depth. Which may not be VERY deep but if you don't have an atmospheric chamber of some sort (like the rest of us) it may be your best option for a simple answer. It's made specifically to harden wood that has suffered from dry rot and for hardening "spalted" pieces of decorative lumber. You can buy it at any hardware store."Take two placebos, works twice as well." Enzo
Originally posted by NFXP View Posti dont want muddy. i want clear."Take two placebos, works twice as well." Enzo
