I just finished my first build, a 7 watt SE using a lone 6v6. Surprisingly to me, the amp worked perfectly right out of the gate! I used a 5F2A chassis, but with a different circuit. I have decided that I would like to mount this in a small head. I have the woodworking experience to make my own cab (I make my own guitars too).
The 5F2A chassis is obviously meant to be mounted vertically. I would like to mount it horizontal, but I foresee two problems.
1. Is there any downside related to the tubes themselves being mounted horizontally?
2. The tubes would only be about an inch above the bottom surface of the cab. Would the heat from the tubes be to much to mount that close to the cab?
Thanks for the help.
