Face Plate layout excel File.
  • Face Plate layout excel File.
    Here's a Excel file with Knob Layouts.
    I left it un-locked so it can be changed to fit your layout.
    I am starting a 2204 build.
    I have it all on one sheet.
    You have to cut it out and tape it together, to drill the panel.
    I am putting it on a 17 inch chassis.
    I will print it on Clear Labeling Paper and stick it on my Drilled Face Plate.
    Good Luck,
    Terry
    FacePlate Knobs.xls
    Terry
    Very cool. Just a question about scale. How do you correlate the column width and row height with actual dimensions?
    I always have to use the sucessive approximation method. (Trial and error)
      All the Knobs are about right on a 8-1/2 x 11" Piece of paper.
      Your right about the trial and error.
      I print on cheap paper and cut and tape.
      I have it all layed out for a 2-1/2 x 17 Inch Face Plate.
      If your familiar with excel you can manipulate the size any way you want to.
      I'm using the Tab 2, 1-11.
      I Drilled the Front Face Plate last Night.
      If I make a Rear Plate Template, I will post it here later.
      Good Luck,
      Terry
      Edit Note*
      I have it layed out to Print in Landscape, not portrait.
      Terry
        This is the version I ended up Using.
        There are some misc. numbers and such.
        You can arrange it in any order.
        If you don't have fancy Laser burners, and Drafting Programs, this is very do-able for the DIYers.
        Good Luck,
        Terry
        Terry
