Or any other light color for that matter. I used it on a black tolex job recently which went well, and thought nothing of marking out some things on a red tolex job I am about to do. Luckily it was mostly on the margins that will be cut off, but I did use it to outline the back panel of a 2x12 Marshall cab. It shows right through now, but it will be against black and on an edge where it shouldn't be seen. I did write on one side panel, I'll shoot that cab panel black and hope for the best I guess. Doh!
Lesson learned, don't use black sharpie on red tolex!
Originally posted by Randall View PostOr any other light color for that matter. I used it on a black tolex job recently which went well, and thought nothing of marking out some things on a red tolex job I am about to do. Luckily it was mostly on the margins that will be cut off, but I did use it to outline the back panel of a 2x12 Marshall cab. It shows right through now, but it will be against black and on an edge where it shouldn't be seen. I did write on one side panel, I'll shoot that cab panel black and hope for the best I guess. Doh!
Ok or use a roller ball ink pen.
nosajLast edited by nosaj; 05-23-2019, 10:46 PM.soldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Randall View Post"The way I read it, Randall says, "It shows right through now", so I think he did mark on the backside"
Of course is was the backside, why would you mark up the front?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
- Likes 1
Like taking a hammer to a toilet with no gloves. Shrapnel's a bitch!
Sorry, just had ro vent about my latest Dumbis moment.
Jusrin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
- Likes 1
Why would *anybody* use solvent type, a.k.a. "PERMANENT" (hint hint) marker on Tolex is way beyond me.
Kids: repeat with me:
1) Tolex-is-porous
2) avoid using solvents to "clean" Tolex.
Least they will do is soak through it, remove and splotch colours, etc. (any colour but black that is)
The point being that if you use a solvent based marker it will go where you don´t want to and trying to clean it will be a mess.
3) even a ballpoint pen which uses grease based ink (hint: only removable with solvents) can be dangerous.
4) if at all needed, try to use water based stuff, or chalk (I use seamstress/tailors type chalk, which allows for quite precise marking and can be removed if necessary with a damp cloth opr plain brushing away)
- Likes 1
Originally posted by J M Fahey View Post4) if at all needed, try to use water based stuff, or chalk (I use seamstress/tailors type chalk, which allows for quite precise marking and can be removed if necessary with a damp cloth opr plain brushing away)
- Likes 1
Originally posted by glebert View PostAnd it looks like big guitar picks!This isn't the future I signed up for.
FWIW, Randall, I've only covered a couple of cabinets and none in red. Without the benefit of your experience I might well have made the same mistake."Take two placebos, works twice as well." Enzo
"Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
In my vast experience (I've done TWO cabinets) I used a chalk line for the long cuts. Probably because I'm really bad with straight lines! I probably did use sharpie for outlining the glue areas. I must have lucked out, working with wine-colored vinyl. Good caveat going forward. I appreciate the post, Randall
Originally posted by Chuck H View PostFWIW, Randall, I've only covered a couple of cabinets and none in red. Without the benefit of your experience I might well have made the same mistake.
Originally posted by nosaj View PostNot a 100% on this but I think Sharpie brand markers will look purple under black lights(bars, clubs , what not)
nosaj"Take two placebos, works twice as well." Enzo
