Okay I want to eliminate as many vibrations as I can. The amp chassis is mostly quiet on a lot of notes but F# and G on the low strings seem to make the chassis vibrate hell for leather when its cranked. I pulled out all the unconnected/loose socket pins and tightened all the screws and nuts I can find, and have tapped endlessly all over the chassis trying to find the source of any noises. I also put door seal strips between all metal and wood surfaces.
So I am thinking it must be some kind of resonant frequency thing going on, that could possibly be amelioraed with improved cabinet design. I have the baffle mounted on two side battens from the rear, with 4 PK screws in each batten. (see pics - please ignore the crappy speaker).
Is there a better way of mounting the baffle to reduce the amount of vibration gettig through to the chassis? (Should I remove the number of contact points between the baffle and the battens - possibly by taking out some of the length of battens?, or should I add more battens to top and bottom?)
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
