Installing Metal Corners
  • Installing Metal Corners
    I've been fussing with the best way to install the Fender-style metal corners for some time. The recess thing complicates the installation, particularly where to drill the holes.
    I just tried squashing both recesses on the corner flat in a vice to locate the center of the hole better. Just fit up the squashed corner and mark with a Sharpie. Drill 3/32" then 1/2" countersink. Now the recessed corners fit right.
    That's pretty much exactly the way Lew and I use to do it too Smitty.
    I made jig with an old corner, used an actual countersink drill bit to kiss the tolex, then move the corner away and relieve the vinyl and the wood under it.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
