Reduce the value of R37, say 10K?
Remove R15, replace the 470ohm bypass resistor (R14) at the 6AV6 with 1.5K/25uf cap.
Remove the NFB loop or put it on a switch? If you remove the loop try a 25/25 bypass cap at R21 (you can put one there anyway but the bypass cap will affect the impact of the NFB loop). By the way I'm assuming that R27 is 2.2K NOT 100K.
Really to get more gain you'd be looking to completely rewire the PI as a long tail pair.
