Originally posted by skydogda
View Post
The other wires are your primaries (one for each end of the primary winding) and your shield. The shield won't be connected to any other wire. The primaries should have a low-ish DC resistance across them.
If you can't tell the colour of the secondaries, very well. The pairs of wires on the windings will all have a low DC resistance across them. The HT will have twice the resistance from end to end as it does from each end to the centre tap. Carefully hook-up the primaries to a wall socket VAC supply, with the shield going to the mains earth, and the HT centre-tap going to the mains earth. Make sure none of the secondaries are touching each other or shorting on anything, then switch it on and (very carefully) measure the VAC across each corresponding pair of secondaries.
