I have this old tube amp: DUKANE 1A435B POWER AMPLIFIER 50W , I was wondering what would be a good preamp that I could build that would compliment this amp. It's intended use would be for guitar. I noticed it has auxillary ouput connections for 6.3 volts and also B+. I will assume this is so I can connect a tube preamp to the existing power from the transformer.
The service literature says: "auxillary power 225 volts DC @7.5ma; 6.3 voltsAC@1.4amps, B+ and filament power for audio preamplifier..."
So, yes all set up for a preamplifier. Anyone know of a good tube preamp for guitar? I know there are many out there. Just can't decide what would sound the best. I like clean, also a little overdrive or extra gain. I would love to have this for bluesy and rock sounds. I have many pedals to use with this amp for other sounds. It doesn't matter if the preamp has a lot of wiring or not, looking for the sound not the complication of it.
I really just want to make a good complimetary preamp, possibly tube or possibly sollid state. I already have an amp case with 12" speaker that I took this out of, which already has a space for 19" rack(for preamp). I made a tube MIC preamp a lonnng while ago that did not have enough volume. So then I made the carlsboro preamp and I could only get one channel to work. But, that was a long while ago.
First thing is I have to recap the amp, real noisy, I also may replace the resistors as the resistance has jumped up considerably on all of the resistors.
I am wondering if the ROG amp simulation circuits would have enough output as a preamp to push the tube amp or would I have to add something else to get a bigger signal to the power amp?
So, a tube preamp is not out of the question, but I am also interested in using ROG type circuits if possible. I play blues, rock, country, country rock, pop and folk.
Thanks for any and all input!
Any suggestions would be appreciated.
Thanks!
Arn C.
Thanks!
Arn C.
