Hi, I want to connect my stereo outputs into one speaker. Is it as simple as using a higher power speaker at a higher impedence? Two 8 ohm outputs at 10 volts would add to 16 ohms and 20 volts, yes?
Or could I connect the outputs together inside the amp before they go through the transformers and then connect an appropriate transformer? I feel this would be best.
I have a stereo tube amp, 6aq5's and would like to make it one output.
Thanks...
Thanks...
