Originally posted by loudthud
View Post
BUT, I also get about 190VDC on the HT supply measured at the plates with the standby OFF...
MY theory is the single diode between the secondary and the HT fuse is half-wave rectifying the current and delivering it through the choke / OT center tap.... To correct this I Interrupted both secondaries with the DPDT standby switch, (while feeding the bias directly from the PT secondary tap), but then I got almost no bias voltage in standby mode, only about -0.4VDC. After flipping standby, I have good Bias voltage in this configuration, but it takes about 3 seconds to charge up after the flip, which as noted above could be a potentially damaging issue.
What is going on here?
