This concerns my EL34 build and it only happens now and then, but i'll be playing and i get a shock from the strings on my fretting hand. But the thing is, it's very subtle, only happens maybe once every 2-4 hours of playing, and when it happens i cannot recreate it again no matter how hard i try with a few exceptions. The shock isn't much more than a 9 volt battery on your tongue sorta thing.
for the record i have a second amp plugged into it's DI out and neither have ground prongs in use due to a extention cord that has no ground pin hole. granted, i can get one and that may end it. But what i don't get is i never got this before and haven't hooked anything up different and this just started to happen last few weeks. The only changes were to the amp's circuit as i tweak it. But i can't think of anything i've done to change any grounds on any way. One thing i noticed the last time it happened is i was barefooted and it's a tile floor. Not sure it's happened with shoes on before, but it probably did. And i don't know if that could someghow have anything to do with it but i thought it was worth mentioning. What kinds of things should i look for?
