Originally posted by GregS
View Post
If my 150 ohm resistor (operating under very similar circumstances to yours) is dropping 43 volts. 43/150*43=12.33 watts
That's at idle. In use the current across that resistor will be on the order of 150% of 12.33 watts. 12.33*150%=18.495 watts.
With safety margin that's a 25 watt resistor. But wait... There's more...
Your amp has a higher voltage PT secondary than mine. So how come we both have 390 +/- volts at the rectifier??? It's because your amp is drawing excessive current right now and this is loading the HV rail. When you re-bias your power tubes (with a bigger cathode resistor) to draw 100% (or preferably a little less) of their rated max dissapation, your voltage is going to go up and you'll be back to square one. So you'll need a bigger dropping resistor than I am using, but probably not 330 ohms. I guessed at 180 ohms and I think that's a good start. I bet it'll be 180 to 220 ohms. So...
The higher value resistor again will require a slightly higher rating. Now the 25 watt won't offer much safety margin and live a hot, hard life close to it's max rating much of the time. Since most resistor ratings jump from 25 watts straight to 50 watts, I say go with 50 watts. You could use two 15 watt or three 10 watt resistors in series or parallel too. But since one resistor looks tidier and is easier to wire in, I say just go with the 50 watt. And as I said before, do otherwise at your own peril.
Chuck
