Originally posted by Jazz P Bass
View Post
Another Bassman Build With Issues (AA864)
Originally posted by mazzas View PostHow high can I go with this value? I'm not certain that I've got a suitable replacement available. I've got a .047 in an acceptable voltage... but that's pretty high.
How much trouble can I get myself in by swapping the OT leads... just to make sure I've got them right?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
After changing the capacitor at pin #2 of the PI (from 500pF to .047), I now get 0.5M reading on the resistor with the power off (changed from 0.08M).
Voltage readings across the resistor at pin #2: 0.58 (barely changed from 0.05)
Voltage readings across the resistor at pin #7: 0.025 (changed slightly from 0.05)
Substitution of a known good 12ax7 for the 12at7 causes the voltage at pins 1 and 6 to oscillate and my meter can't get a reading on them.Last edited by mazzas; 08-04-2009, 11:35 PM.
I want to sincerely thank all of you for your thoughtfulness and help. I've located the problem: a short in the signal path. It was a stray strand of wire from the OT signal lead on the speaker jack that was touching the chassis. The strand came from "underneath" the connection so that I could not see it. I found it when, in desperation, I decided to wire a single output jack.
I learn quite a lot from these builds and even the false leads and blind alleys show me something that I didn't previously know about the amps I build. I am greatly reassured that we have such an engaged and talented community.
Please feel free to PM me and I'll send you a beer.
I am assuming that it should not induce a fairly loud tapping noise when I tap on the PI tube. If my assumption is correct, can I further assume that the tube has gone microphonic? Or is this somewhat standard for these tubes? Or is this indicative of something wrong?
Usually it's the first preamp tube that will develope a microphonic 'ping'. Many times the tube will be ok further down the signal path because the signal is bigger. If the PI is making some other kind of noise I would suspect a bad tube (one with a broken weld or melted grid) or poor contact with the socket. On a new build, a bad solder joint is a possibility. The so called 'chop stick' test helps locate these type faults. Poke around at the connections and wires with something insulated while the amp is on. Don't use a lead pencil !WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
