did i kill my pt?
  • did i kill my pt?
    i think i might need a new pt for my pr build. i was planning to use the 50v bias tap availible on my allen pt, so i put a 470 ohm bias resistor in but at the last second i wired the bias supply from the rectifier. when i fired up the amp i got crazy ma reading something like 10k or 100 ma, i shut it down, looked inside and saw what i did so i changed the bias resistor to the correct value(100k) and the amp worked great, for a while, then the rev and trem stopped working. then i noticed if i turn the amp off then on the rev and trem worked for a minute, then went off. i checked inside and found the rev driver tube voltage was very low so i put in a new tube and all was good , anyway the amp worked fine for a while then it started humming. i turn the amp off then on again and it works for a minute the hums again, it did this for 30 minutes or so and finally went strait to full blown hum, loud like touching the speaker wires together. anyway i think firing the amp up with the small bias resister killed the tranny. but im not sure.
    Hi Scott - Did you try a third tube? (the 2nd one could've been a dud)
      yes i did try a few tubes. i wonder if it could be a bad tube socket. i used the mojo fake beltons.
        You should check the caps in your bias supply. They probably got hit with some serious voltage when the 470 was in there. Other than that, I don't think anything you did would cause the PT to fail.
          man thats good news. im going to look into that in the am, thank you loudthud
            no good. the cap and diode are ok, what next?
              Have you got a B+ voltage, and what are your voltages at the filter cap nodes?
