Have a new 5E3 build from Tino Zottola's 2nd book completed. The amp works and sounds fair however, it has a good amount of hiss to it. I checked all the mechanical connections and they're all good. Pulled the preamp 12AX7 and it went away. Swapped tubes with known good ones and no change. When I checked the voltages, pins 1 & 6 of the preamp and phase inverter read very high (Read pin 1 215/183 should be 175/135, pin 6 173/170 should be 140/135). Both are 12AX7's. Pin's 3 and 8 read low, with pin 3 having 45.7/1.3 should be 55/1.5. Pin 8 having 1.29/1.4 should be 1.5/1.5.
This seems to all be supplied by the B+++ voltage. Any thoughts on how to bring these voltages back into tolerance? Could I just change the resistor value in the filter or does it seem to be something more involved? Any help would be greatly appreciated!
Thanks,
Thanks,
