I posted this over at the Weber site forum too but feel more at home here...![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Sorry this is little long...
A little background:
I've previously received a Weber 5F6A kit, assembled by someone and sold to the customer, for some troubleshooting with hum/buzz, etc. The build wasn't stellar, but after some tightening and looking after the grounding as well as some component mounting issues all was good. I thought it sounded pretty darned good too as a matter of fact. The filter cap setup is the small mini-board mounted inside the chassis. Rectifier tube is GZ34.
Fast-forward to the present:
Customer has brought the amp back for installation of all new iron - specifically Mercury Magnetics FO50BM-2 OT, FC-2.84 choke, and FTBP-58 PT. Aahh - the never-ending quest for tone.
Problem is the new PT & choke combination would exceed the voltage rating of the kit filter caps (20uF/450V on the extra board assembly) by a bit. Glad I used a variac, as I got to 445VDC at about 115VAC line voltage with all tubes in and biased reasonably close. Opening the standby switch pops the rectifier output up to no-load 470VDC, which of course is what the first stage filter caps will see momentarily when the standby switch is closed again. Actual line voltage around here ranges from 119VAC to 124VAC depending on time-of-day and/or time-of-year. I figure at 120VAC the first stage will be at about 465VDC with standby closed and something like 482VDC with it open. The choke measures only 35 ohms DC resistance and doesn't drop much into the next stage.
I notice the original 5F6A schematic shows 600V filter caps, but the 20uF Sprague Atoms currently available at that voltage are freakin' HUGE! I think I could fit some 100uF 350V caps in series on the little board to replace the two 20uF 450V, and I might be able to do the same with a couple 47uF 350V to replace the next stage 20uF 450V. I think the following stages will be OK after the dropping resistors.
I'm wondering - if faced with this kind of high B+ scenario what would some of you old hands do? Up the cap voltage rating? Or look at lowering the B+ through use of a different rectifier tube or zener diode in the center tap? Or some other possibility I haven't considered?
Thanks!
Mark
Thanks!
Mark
