Hello my fellow solder fume breathers.
My latest build is a copy of a 5F6-A or JTM45. I've used Ace Peppers schematic (you can find it here: http://www.sonicdeli.com/ThunderTwea...o/P-Matic2.pdf with a few tweaks (actually I tried to keep the circuit close to the 5F6-A in the clean channel).
The first triode has a 1.5k cathode resistor and a 22uF bypass cap. The second triode has a 4.7k cathode resistor and no bypass cap so far.
For the power stage I use two JJ 6V6s with 470R/2W screen resistors. I changed the 220k series resistor before the cap to the PI to a 100k and inserted a reverb circuit here (see attached schematic).
When I turn the amp on, it's dead quiet but as soon as I touch the plates of the PI with a meter it starts to squeal like crazy and won't stop (guess how I found out ).
When I put a guitar cord into the input and touch the other end with my finger tip nothing happens (except the normal hum) until I turn the volume up to say 2 or 3 then it starts to squeal too.
When I disconnect the 0.022 cap (before the PI) from the preamp and touch the plates of the PI the amp doesn't squeal so I assume the power stage is alright (I haven't inserted a different amps preamp signal here, yet).
Tried different tubes to no avail.
Voltages are all within 5% of spec.
All resistors in spec.
Have disconnected the second channel to no avail.
I'd really appreciate it if you got any ideas where to look next.
Thanks
Matt
Thanks
Matt
