Dear all,
So I rebuilt my friends Gibson atlas amp. It seemed like a fun project and I could use the practice. The amp had so many problems plus there wasn't much original to save within the amp, so gutting it rebuilding it from scratch seemed like the best idea.
Here's a schematic if you're interested: schematic
The only parts that are still original are the power transformer, the choke and the chassis. I used carbon composites for most of the resistors and orange drop 715p caps for pretty much all the coupling capacitors.
For the elco filter caps I got 22uF's instead of 20uF as stated in the schematic.
I modified the bias circuit to make it adjustable, and I set my matched 6L6's to draw around 35mA at idle. Maybe a little low but bringing it up also brings up the hum I'm trying to get rid of.
I've star grounded the circuit at a point somewhat in the middle of the amp.
I'm using a proper three stranded power cable and the chassis is grounded with it (not at the star-ground point I'm afraid).
So my problem now is the hum and noise the amp produces even without a signal going through it. I've made a little video so you can get an idea of what I'm talking about. See: YouTube - Gibson Atlas Hum
My guess the problem is coming from the power transformer, if so I might not be able to fix this amp any further which would be nice to know. With the amp on standby the transformer hums somewhat audible to about the same frequency (to my ears at least). I've tried using different, known to be good, tubes with no result. Also poked around with a stick to see if the wiring might be causing the problems. Although I know I could have done a better job at wiring I don't think its the problem. Click for full size Sorry for the crappy phone cam picture... I can get better ones if needed.
I'm interested in whether all the wires are connected right since there aren't any markings on the transformer. For example the white and the black/yellow wire are connected to each other in this amp. Now I should probably mention I live in the Netherlands (230 v mains) and my guess is the wires are connected perhaps for this reason. I'm not even sure if this amp was produced for european usage. In any case I think the power transformer is original, the number on the cover matches the one from the schematic.
The output transformer probably isn't original since this amp now has a 4, 8 and 16ohm output.
I'm pretty happy so far, the amp sounds nice and warm. A lot of low-mids, which I kind of like. It's different.
In case you have any simple adjustments to the circuit that could improve it's sound, I'd be happy to know them. I read somewhere that lifting the .047uF caps (c14, c15) from the ground opens up the sound, which I might try.
