It is impossible to predict the results, but you should attempt to modify the PCB by cutting tracks and adding wires. Since I suspect English is not your native language, I will try to define some words. If you do not understand, please say so and I will try to make things clear for you.
PCB: An abreviation for Printed Circuit Board.
Crosstalk: Is an electrical phenomenon where a signal or noise from one wire leaks into another wire in close proximity even though there is no direct connection between them.
A PCB has two sides. One side is where you mount the components. This is called the Component Side. The other side is where the components are soldered to the tracks. It is called the Solder Side.
You will have to cut some of the copper tracks on the Solder side of the PCB. You will need to use a sharp knife. I have marked some of the places to make cuts on the attached photo. They are marked with a red X. You should actually make two parallel cuts about 1 millimeter apart and carefull remove the copper between the cuts to insure that there is no connection.
Because I cannot see all the tracks, you will have to determine where to make some of the cuts. There will be some copper tracks on the board that will not be connected to anything. This is ok. ("ok" means acceptable.)
The objective is to disconnect the heater voltage (6.3VAC) tracks around V1 and the replace the tracks with a twisted pair of wires from the connector block (where the heater voltage is connected to the transformer) to V1. Then another twisted pair of wires will connect the heater voltage from V1 to V2. It should not be necessary to replace the tracks between V2 and V3/V4. The circuits there are less sensitive to crosstalk.
Pins 4 and 5 of each 12AX7 should be connected together directly between the socket terminals. If there is a track routed between pins 4 and 5 that is connected to a resistor or capacitor, you should cut the tracks connected to pins 4 and 5 and connect them together with a short wire.
There are two green wires that I have marked to be removed. I think these are connected to the 6.3VAC. If they are not, then do not remove them.
You will need to determine what tracks are necessary to connect the 6.3VAC between V2 and V3/V4. Cut any tracks that may be connected to V2's heater pins but are branches that don't carry current to V3/V4.
Once the tracks are cut, solder a twisted pair of wires on the Solder side of the PCB from the connector block to V1, and then another twisted pair from V1 to V2. You do not need to observe polarity of the wires. The wires should not lay against the PCB but should be bent so they are suspended in air about 5mm away from the PCB until they are bent down and soldered to the socket pins of the tube socket.
Once the connections are complete and before you apply power, remove all the tubes, disconnect the 6.3VAC wires from the transformer and measure the resistance between the two screws at the connector block. You should measure an open circuit. If not, you have created a short that could damage your transformer if you apply power. You must eliminate the short before you apply power.
I have also marked a track to cut near R1. Solder a shielded coax cable on the solder side of the PCB and use that to connect to J1. Be sure not to create a short to other tracks on the PCB when you solder the coax. If you cannot obtain suitable coax cable, use a twisted pair but you will have to observe polarity when you solder to J1.
Grounds: The input jack in the picture looks like it is the type that connects the "sleeve" to the chassis. The speaker jack looks like the same type but may have a black insulating washer. If both of these jacks have the ground terminal connected to the chassis, a ground loop is created that may cause noise or oscillation. One of these jacks should be insulated from that chassis with plastic washers or you can use a plastic jack. There should be a connection to the chassis near the connector for the power cord for safety reasons.
Pilot light: It looks like you are using a 6.3VAC pilot lamp. Make sure that neither terminal of the lamp socket is connected to the chassis. Is there a connector on the PCB for connecting the 6.3VAC to the pilot lamp? Do not run wires from the left side of the PCB past the pot to connect to the pilot lamp. It would be better to solder a twisted pair of wires to the 6.3VAC at V3 of V4 to connect to the pilot lamp.
Power Switch: Your power switch does not have 4 terminals like the one on the schematic (S1A, S1B). It probably violates safety rules in your country to use a two terminal switch. Your instructor may deduct your grade if you do not comply with safety regulations. Route the wires between the power cord connector, the fuse, the power switch and the transformer along the right side of the chassis, and across the back side of the chassis. Do not route they past the input jack and the pots. Use a twisted pair of wires that are rated to safely handle the line voltage.
What you have learned: Crosstalk on PCBs must be taken into account during layout. You can not simply place components at random and "connect the dots".
