My first Amp build...
Triode Champ Amp Kit... 15watt Upgrade Transformer to run 6L6's... Separate On-Off switch... 470ohm 10 watt power resistor instead of the 5 watt...
I have a Humm problem... Volume control works, dosen't effect the Humm... I get Guitar sound from both inputs... Fuse dosen't blow, no smoke...Checked all grounds till I'm blue in the face... I've re-soldered most of them... Star grounding on Power Transformer Bolt...
I do notice some weird problems... When I turn it off, the Dangerous Filter caps drain themselves... Pretty Safe Amp, but I don't think it should do that...
Voltage Checks yield weird High readings... From L to R on the Weber Layout, I get B+ at 400vdc, not 340... next I get 400, not 275... next I get 352, not 250... then I get 30, not 18... and 252, not 150... and 250, not150...finally I get one right, 1.5 is i.5...
I'm about ready to give up...
Thanks,
Meaux
Thanks,
Meaux
