Hey all, Just finished up my scratch build(Mojo small parts kit, 65 BFTR Reissue chassis & MM transformers) & I have a few issues:
1. Tremolo(speed & intensity pots) do not function at all
Note - Footswitch is plugged in & respective tube is "known good". Also triple checked all solder joints & all A-OK..?
2. Reverb is oscillating(gnarly high pitch squeal that increases when dialed up).
3. When the Vibrato volume pot is dialed up past 7 the volume for channel 2 cuts out completely
Note - Brand new Mojo pot with all proper connections & good continuity to ground(chassis).
Any ideas on what to do here or where to look? I've already tried the "drumstick method" to search for loose wires, bad components, to no avail.
Any help is much appreciated!
