I've been building a Plexi copy a-la Kevin O'Connor's TUT3 Plexi. I have made it as close as possible to his suggested layout in the book (photo attached).
The main differences from TUT3 Plexi is that I have made it a 4 x 6V6 output section, similar to the TUR3 Laney project.
The amp has a strange parasitic oscillation. The amp is hooked up to a 8ohm dummy load, but thanks to the vu Meter I fitted, I know this amp is oscillating. I did the following things in this order and nothing changed:
1 - Swapped OT output leads - No Change
2 - Disconnected negative feedback loop - made no difference
2 - Added 150pF capacitor between plates of PI tube (there was no cap in the design) - No Change
3 - Added 680pF Grid-to-Ground caps on all output valves - No Change
4 - last ditch effort, removed 150pF from PI anodes and replaced with 1000pF - No Change other than the side of the OT with most oscillation seems to swap.
None of the above worked, but one interesting thing does happen. The control knobs are not yet fitted, and when I touch the volume pot shaft to alter gain, the oscillation disappears! What the hell is going on here?? Very confused!
