I just finished a JTM 45 kit from Mojo and there are issues. The b+ is near 500VDC at all b+ points with just the GZ34 in. Granted, the pre and power tubes draw current, but isn't this a bit high? When I put the pre's and power tubes in I got smoke from the middle of the board. I had them in before and got no smoke but very high b+ readings in the preamp. like 300 +. But this time when I got smoke I immediately shut it down and checked continuity fro the board to the tubes and the board to the pots. All were fine. I just don't know what to do next....Any ideas? Thanks guys....
JTM 45 build
Some gut shot pictures would help.
Also Metro has an instruction manual you can download, that has a power up section.
TubeDepot has one too.
They show voltages with and without tubes.
Here are the links to the manuals.
http://metroamp.com/wiki/index.php/J...t_instructions
http://metroamp.com/wiki/index.php/5...t_Instructions
http://site.tubedepot.com/pdf/jtm45plus_v4a.pdf
http://site.tubedepot.com/pdf/jtm45plus_v4b.pdf"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Jtm 45 kit instructions - MetroAmp Wiki
50 Watt Kit Instructions - MetroAmp Wiki
So are your voltages similar to the Instruction charts?
Maybe that will show you where your problem or wiring error might be?
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by MikeT View PostTerry,
I can't check the voltages with the tubes in because the board starts smoking...not good! I have a feeling it is a problem underneath the board, because there was continuity to the chassis where there shouldn't be.
Mike
May be a good time to build that Dim Bulb tester.
They are great for what I call Poor Boy Power up!
dim bulb tester - Google Search
Good Luck,
Terry
