So I have built this amp: http://jussii.tk/tmp/6v6.JPG
Power supply is from "plexi 6v6" by m. huss
Currently I don't have the internal PT secondary fuses installed at all because I wan't to test only heaters first.
If I pull out all tubes and start the amp the heater voltage is 6.3V and led is glowing. If I install tubes and start the amp: led flashes and main fuse (1A) blows. I don't understand what could be the problem.
From this picture you can see how my heaters are wired and I've checked they are the same in the build: http://jussii.tk/tmp/heaters.png
Any ideas?
Any ideas?
