I just finished an experiment of sorts - a 5F2A running 2 - 6V6's in parallel. The amp sounds wonderful, but it has a pretty significant hum. Most of the amps I've built over the years have been push-pull. So I know that SE amps can be a little hummy, but I think this is excessive. The volume control has no affect on it. In fact I seem to remember the hum is there even with V1 pulled. So I'm thinking either a ground issue or maybe I need to move the OT around a little to see if that helps. But now that I think about it, the hum doesn't show up until the tubes warm up, so maybe the OT position is OK. I'm using the brass plate with everything except the Mains ground going to it. Filament CT goes to 6v6 cathode. Now I'm thinking I should chuck the brass plate and do a buss across the pot backs for the preamp stuff to the input jack ground, and ground the power amp and power supply stuff over by the PT. Incidentally, the OT I'm using is a Classictone 18031. It is currently mounted on the opposite end of the chassis from the PT. I used the 5K primary and have a 4 ohm speaker load hooked to the 8 ohm secondary tap.
I know grounding issues have been beaten to death, but I'd still appreciate any advice on chasing down this issue.
