Okay, okay. I know, two threads on the same build? What an idiot! Everything stock on the amp is great, but my "mod" ideas are causing a little havoc at the moment.
So I put in a DPDT switch to switch in a fixed bias circuit for a different sound coming from this amp when wanted. To create negative voltage, I stole AC from pin 4 of the rectifier.It runs through your standard fixed bias circuit (dropping resistor, diode, bias caps, load resistor, pot) which is left open until the switch is thrown. The switch lifts the ground of the 220K grid resistor and connects it to the bias supply.
Everything seems to do what it's supposed to. When the switch is thrown, I get negative voltage on pin 5 of the output tube. I can adjust the bias on the tube appropriately.
However, the fixed bias circuit is injecting a lot of noise and distortion in to the circuit. Super loud hum and very gravely distortion when the amp is played. The hum is so loud that I'm afraid to keep the amp on for very long even though the voltages are checking out okay.
Any ideas? What have I got my self into? Some of the wire runs seem fairly long. I left the 220K in place and ran a wire from it to the switch (underneath the board, beneath the filter supply). The switch is located between the rectifier and the power tube. The negative voltage bias supply is glued to the chassis between the board and the power transformer.
Thanks!
Morgan
Thanks!
Morgan
