Powering up my amp
  • Powering up my amp
    I finally mustered the courage to turn my new build on today (the
    FrankenstAmp one over in "Build Your Amp") and I may have a problem
    but I'm not sure.
    I plugged my amp into my Dimbulb with a 15w bulb in it. When I turn it
    on with no tubes in the amp (which uses a tube rectifier) the bulb glows
    at maybe 25% brightness. My PT is 320-0-320 and I get 222vac at
    pins 4 and 6 of the rectifier socket. Heater taps are 2.3 and 2.2 vac
    (I've got a balance pot). My 50vac bias tap is at 35vac. So far things
    seem ok though I'm not sure if I should be getting any kind of glow from
    the bulb.
    Next I plugged in two different RCA 5U4GB rectifiers which both test off
    the scale good on my somewhat basic Triplett tube tester. When I turn
    the amp on the 15w glows at full on. I haven't dared go any further than
    this.
    Is it possible that the lamp is glowing brightly while my 2x20uf first stage
    filter caps are charging up and that I don't necessarily have a short ?
    I've gone over all the wiring a few times and nothing looks wrong.
    When I saw the bulb go full on I immediately shut the amp off. How much
    time does it take to charge the caps ? I did notice that B+ measured at
    the filter caps stayed at zero but perhaps the multimeter didn't have enough
    time to display a reading before I switched the amp off.
    With the amp off if I measure the resistance across the filter caps it starts
    off at about 320K then falls constantly down from there. I presume the
    caps are charging with the resistance-measuring voltage but this causes
    the resistance to go down ?
    Any help would be much appreciated.
    Paul P
    Try plugging in an old rectumfrier that you know works and some old reliable tubes, and switch it on with the meter connected to the B+ and watch closely for smoke.
      Problem solved, which was the 15w bulb. I think there wasn't enough
      power getting through to operate the rectifier tube, even though it was
      enough to light the bulb brightly. I replaced it with a 100w bulb and was
      overjoyed to see my B+ climb up to 412v using a new JJ GZ34. I then
      put a 5U4GB back in and B+ went immediately to 399v.
      Now I'll measure all the other voltages.
      Paul P
        Hey, the thing actually works !
        Well, sort of. I get a real nice clear tone from my signal generator but
        there's still something not right at the power tube.
        My circuit right now is close to a Champ. One Tung-sol 12ax7 and one
        SE 6v6GT, also Tung-sol. I switched the rectifier to a NOS RCA 5Y3GT.
        When I first took the amp off standby I measured about 70ma through the
        power tube cathode both with fixed bias, at about -40vdc, and also when
        switched to cathode bias. Needless to say when I went around back to
        see what my power tube looked like there was this faint red glow coming
        from inside. (The amp sounded great though and NO hum).
        I shorted my bias circuit's newly installed dropping resistor and got the
        current through the cathode down to 39ma with -56v worth of bias and
        the power tube stopped glowing.
        So something isn't right. Here are the numbers :
        PT secondary 329-0-330vac (spec says 320-0-320)
        B+ first filter on standby 442 vdc
        B+ first filter off standby 430-440
        6v6 at plate 382vdc
        6v6 at screen 385-387vdc
        bias -56vdc
        B+ to preamp 353vdc
        VIa,b plates 240vdc
        First of all, isn't my B+ kind of high for a 5Y3GT ? I also find it a bit strange
        that the screen was higher than the plate, though this may just be due
        to variations between measurements of my AC mains which seems to vary
        quite a bit. I'm using a 470 ohm screen resistor and have a 100 ohm 3H choke
        between the plate and the screen node. And a 470 ohm cathode resistor
        bypassed by a 25uv 50v cap when switched to cathode bias.
        Any ideas where to go from here ?
        Paul P
          You might just have an efficient 5Y3GT.
          As for the screen voltage, try chucking a (1k5? - 5k?) 5W grid resistor at the screen grid pin and see what that does
            I retook the measurements this morning. I may have gotten a few things
            confused yesterday but the fact remains that the voltage at the screen is
            higher than at the plate.
            Here are some more accurate numbers, using a NOS RCA 5Y3GT :
            On standby :
            AC mains.......... 120 vac
            PT secondary ..... 336-0-335 vac (spec 320-0-320)
            B+ first filter... 449 vdc, 150 mvac
            Heater bias....... 48 vdc
            Filaments ........ 3.4--3.3 vac
            Off standby :
            B+ first filter... 391 vdc
            6v6 at plate ..... 384 vdc
            screen node ...... 389 vdc
            6v6 at screen .... 388 vdc
            preamp node ...... 355 vdc
            V1a,b at plate.... 236 vdc
            6v6 cathode current at idle :
            cathode bias.......... 48 ma
            fixed bias at -57 vdc, 39 ma
            Paul P
              paul, i went through this with my champ. for some reason only fender can make a 6v6 sound good at about 400v on the plates, the rest of us have to get that plate voltage down to about 350, otherwise the amp sounds stiff as a board. refer to this thread:
              http://music-electronics-forum.com/s...ead.php?t=4879
                Thanks for the help tubeswell and scole. I changed my screen resistor to
                1500 ohms (only had a 2w on hand but that should be ok for the moment)
                and that brought the screen down to below the plate. As far as the amp
                sounding stiff, I don't have enough experience with amps to really know
                what that means. I've been strictly an acoustic guitar player though my
                daughter has a Fender MIM Strat Jr and a small Vox Pathfinder 15r ss amp.
                I also played with the decoupling resistors. Here are the updated voltages,
                off standby :
                B+ first filter... 384 vdc (2 vac)
                6v6 at plate ..... 378 vdc
                screen node ...... 383 vdc
                6v6 at screen .... 375 vdc
                preamp node ...... 307 vdc
                V1a,b at plate.... 205 vdc
                fixed bias at -51 vdc, 48 ma
                Not sure if this is ok or not. Looking at the power tube with all lights off
                I see a very faint glow in a band about 1/4" wide top to bottom. Is this
                just the heater showing through ?
                I'll talk about the amp's performance back in the main thread.
                Paul P
                  Hi Paul P
                  That screen voltage still looks too close to the plate voltage. You might try going to a 2k2 or 4k7 5W screen grid resistor in there. If it destabilises the rest o fthe power supply too much, then decouple it with a 10uF 450V cap to ground with the +ve end at the screen grid pin
                    I'll try a 4.7K screen resistor later on today.
                    My main problem is that my poor 6v6 is dissipating 17w. Too bad I
                    can't leave it like this, it sounds good. I can get this neat sort of "whump"
                    or "pwop" to each each note and chords are full of all sorts of harmonics
                    bouncing around all over the place (maybe a bit too much so, but I'm using
                    my daughter's strat with its 22-3/4" scale and the strings are a bit like
                    rubber bands).
                    Paul P
                      What sort of tube is it? I'm running one of those new-fangled New Sensor TungSol 6V6GT 'reissues' in that 5F2A I just made and it seems to happily handle a plate voltage of 364 at idle, and seems to do some of those neat things you describe
                        I'm also using a Tung-Sol 6V6GT.
                        I'm going to move my choke to before my first filter (just have to switch
                        a few wires). Hopefully the choke won't radiate too much hum. This should
                        drop my B+ down to some reasonable level. Then I can easily drop the
                        screen to something lower.
                        Paul P
                          Well, changing to "choke input to filter" dropped B+ alright. Right through
                          the floor ! All the way to 280vdc at the first filter caps using the 5Y3GT.
                          With a GZ34 it move up a bit to 296vdc.
                          Doesn't sound so great either. Kind of dead, no prettying up of the sound
                          of the guitar strings. Like an acoustic only louder. Not terribly loud and
                          there is some distortion at the upper end of the volume. Also, a funny
                          thing, one note sounds clean but two notes or more together causes a
                          mumbly background confusion. None of the neat sounds I was getting
                          before.
                          This change played havoc to the other voltages. Here they are for the record :
                          With 5Y3GT :
                          ...On standby :
                          PT secondary ..... 334-0-334 vac
                          B+ first filter... 417 vdc, .85 mvac
                          ...Off standby :
                          B+ 1st filter cap. 280 vdc, .75 mvac
                          6v6 at plate ..... 275 vdc
                          screen node ...... 272 vdc
                          6v6 at screen .... 267 vdc (1500 screen resistor)
                          preamp node ...... 220 vdc
                          V1a,b at plate.... 144, 146 vdc
                          cathode bias, 470 ohms .. 32 ma
                          With GZ34 :
                          ...On standby :
                          B+ first filter... 421 vdc, .80 mvac
                          ...Off standby :
                          B+ before choke... 296 vdc
                          B+ 1st filter cap. 292 vdc
                          6v6 at plate ..... 288 vdc
                          screen node ...... 285 vdc
                          6v6 at screen .... 281 vdc (1500 screen resistor)
                          preamp node ...... 230 vdc
                          V1a,b at plate.... 151, 153 vdc
                          cathode bias, 470 ohms .. 34 ma
                          Back to the drawing board .
                          Paul P
                            In that post Scole put up earlier, Bruce from Mission Amps suggests 9.1v to 15v, 5 watt zener diodes (reverse biased to ground off the center tap in the high voltage secondary of the PT) to lower the B+
                              Bruce also suggested using a choke but I think scole was using a PT with a
                              higher secondary than mine. I don't have any zeners lying around and adding
                              one or two in my amp could be a bit of a pain but if it's the only way...
                              Another thing is I'm going to be adding more circuits to my amp which
                              should lower the B+ some.
                              Tomorrow (today to you) I'm going to get the other voltages to their
                              proper levels and see what the amp sounds like. This will give me some sonic
                              experience at the "low B+ high current" end of things.
                              It's really nice to be able to hear the differences in tone I've only read about
                              till now.
                              Paul P
