The volumes pots of both channels of my amp are very scratchy, the Vibrato channel quite a bit more than the Normal channel.
The pots are PEC's, close to new. I've read about them being noisy on their own, but for the moment I'm presuming they're ok.
The preamp circuits are from brownface Fenders of the Bandmaster variety, like the 6G7-A.
Normal and vibrato preamps are identical except for their output configurations.
Inputs are isolated from the chassis and all grounds are connected to a local star point (ref. Aiken).
Signal carrying leads are shielded with the shield grounded at only one end.
The 68.1k resistor below the Treble control is to simulate the tap on the pot in the original amps.
I've checked for DC in and around the volume and tone controls and found some, but it's far from constant.
Here is the situation as I've been able to determine so far :
This wire is shielded at one end, about 5in (12cm) long and runs along the wall of the chassis.
Preamp circuits are at the right, vibrato in the middle, reverb on the left (the photo is upside down)
- in general, there is no DC on any of the pots and no noise out of the amp. A sine wave going in produces a nice sine wave at the speaker
- turning the Volume knob generates a lot of crackling, louder with the Vibrato channel volume pot
- for the Normal channel, only moving the Bass pot can I get DC to appear along the connection between Bass, Treble and Volume pots. This DC is constantly varying and around 0-15 mvDC. This usually stops as soon as I stop moving the Bass pot, but I can sometimes set it so that it keeps going.
- for the Vibrato channel, while the volume knob is turned, DC appears on the grid of V1b (maybe also on Normal channel, but a lot less)
