Originally posted by Helmholtz
View Post
Hum in new AB763 DR build Reverb circuit - increases as reverb pot is turned up
Originally posted by Chuck H View PostYour tank/pan seems to be wired correctly. Only the output jack - (ground) should be connected to the reverb chassis. Continuity other than zero could be transducer resistance as Helmholtz noted.
Here's a diagram of the MOD reverb jack board. You should have no solder on the split pads for the input jack and a soldered connection on those pads on the output jack.
What next?
It could still be magnetic hum picked up by the output transducer from a nearby hum source.
To test, short the reverb output transducer leads inside the shell.- Own Opinions Only -
Originally posted by Helmholtz View PostIt could still be magnetic hum picked up by the output transducer from a nearby hum source.
Originally posted by vintagekikiOutput coil (~ 600 ohm) from reverb tank is located below the main transformer and collects hum from PT (TR1).
Rotate reverb tank 180 degrees so that input coil (~ 10 ohm) from reverb tank is below the PT (TR1)
Assumption that cables from reverb tank to the AB763 DR are shielded.
Is there some problem for upload real schematic and wiring layout of your AB763 DR?It's All Over Now
Originally posted by vintagekiki View PostWe may be strenuous in our questions, but all participants in topic try to help you.
I'm interested what happens if disconnect your reverb tank together with connecting cables from your AB763 DR and in set connect to another amp.
Everyone's help is certainly very much appreciated! Doing my best to answer all the questions.
Originally posted by g1 View PostDid you try the shorting of the output transducer from post #48 ?
I seem to have maxed out my upload bandwidth - the forum won't let me upload anything. And I don't have a schematic for this amp. It's an AB763 with these mods tacked on:
-robrob normal channel reverb mod
-robrob lead channel mod
-3 way NFB mod
-slow tremolo mod
https://robrobinette.com/AB763_Modif...nel_Reverb_Mod
I pretty much followed his layouts, except I added an extra eyelet to accommodate the added 220k resistor before it joins the vibrato channel going into the reverb. There's a jumper under the board that takes the signal from the 220k resistor to where it joins the vibrato channel's signal right before the 500pF cap.
I hope this helps.
