okay I just finished my 5e3 kit from Triode. everything went smooth all the way thru start up. but it has very low output. what I can hear sounds okay it's just way to low. voltages check out I'm checking to see if I missed something but any help will be preciated!!
5e3 build super low output??
triple check your wiring and componentry against the layout diagram and use your DMM R-meter to check for continuity (with the amp switched off and unplugged) between all the points that should be connected. You may've missed a wire somewhere or possibly wired it wrong. Also you may need to reflow the solder on some of your eyelets/turrets.Building a better world (one tube amp at a time)
ok I figured out my problem. I put individual jacks for the 4,8,and16 ohm output and tied the switches to groundanyway the amp sounds killer but hums like a MOFO. I've spent the last few day moving grounds fooling with lead dress but to no avail. still trying to figure it out! any thoughts I'll listen.
Originally posted by dwhutchens View PostHave you tried grounding it to a PT bolt to see if it makes a difference.Originally posted by dwhutchens View PostIs the hum affected by the volume control?Originally posted by dwhutchens View PostDoes grounding the first preamp tube grid make it go away?
I just re did my filament wires and it made no difference. It's gonna feel real good when I figure this outLast edited by mbailey; 08-18-2009, 06:42 AM.
Does the hum instantly go away when the amp is put in standby mode, or does the hum fade out over a period of a second or two? (If you don't have a standby switch, use a rag to pull the 5Y3, while the amp is operating.) Are all the filter cap's grounds connected together on the eyelet board (that can cause hum).WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostDoes the hum instantly go away when the amp is put in standby mode, or does the hum fade out over a period of a second or two?
Originally posted by loudthud View PostAre all the filter cap's grounds connected together on the eyelet board (that can cause hum).
I've shielded the input wires from the jacks to the 68k res. and from said res. to the tube still hums. I've lifted the inputs from the chassis also no change.
as I said before its gonna feel real good when I figure this out!!
Originally posted by mbailey View Postit goes away instantly
Any hum that comes from the heaters or input wiring will fade out when the amp is placed in standby mode.
In general, move the ground of the first filter cap and the red/yellow wire closer together (or at the same point) and the ground for the preamp filter further away. At the same time one would like the ground wire from the first cap to the chassis not to be any longer than necessary.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostIn general, move the ground of the first filter cap and the red/yellow wire closer together (or at the same point) and the ground for the preamp filter further away. At the same time one would like the ground wire from the first cap to the chassis not to be any longer than necessary.do you think this could be a bad component and if so where would you start? I've tried different tubes of course!
Many times hum is a combination of 60Hz and 120Hz. Moving the heater CT to a positive voltage like the cathodes of the 6V6s will only reduce the 60Hz component. It sounds like a low organ note. 60Hz can also be picked up by wires too close to the heater wiring. But the 60Hz will fade slowly when you put the amp in standby mode.
The 120Hz is usually a buzz type sound that comes from the power supply. Sometimes moving the red/yellow wire from the chassis to the ground side of the first filter cap will reduce the buzz.
The next place to look is how the input stage and the rest of the preamp is grounded. Can you post a picture or a link to a diagram you followed?
For bad components the first place to look besides tubes is the filter caps. If you have a spare, tack it across the first filter to see if it changes anything.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
here is a link to the layout I started with but I have moved alot of grounds around trying to get rid of that hum
I tried the extra cap trick and it made no difference
http://site.triodestore.com/5E3_Layout_Diagram.bmpLast edited by mbailey; 08-20-2009, 07:57 AM.
Please look thru the following threads. They deal with some of the issues that can cause hum. Pay attention to ground and input jack problems.
http://music-electronics-forum.com/t12663/
http://music-electronics-forum.com/t13912/
http://music-electronics-forum.com/t13689/WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
