Originally posted by g-one
View Post
I love the 5e3. Just not mine! Please help.
Try it. Meter set to ohms, one probe at each end of the cap. (the cap that goes to pin3 of the 12AX7)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Well that's it for me. I'm freakin stumped. Clean build. Good solders. Can't find anything wrong visually. Still pretty much no volume and it's slightly distorted. Checked grounding points. They're good. Speaker maybe? It should be good. Tested it and know what the positive and negative leads are on it. So it's hooked up right. Jack inputs look good for the speaker also. Guitar inputs and pots are nice. All wires are to their correct post. All caps are correct. All pos and neg sides of caps in the right direction. Back of board is wired right. Fuse wires seem right. Same for on/off and light. Tubes light up. All voltage readings are ok except pin 3 on the 12ax7 or whatever was on the readings.
About to take this to a tech but damn! That will piss me off. I wanted to build this and really learn.
You can still learn if you take it to a tech. They will usually talk shop with you about what happened and what they fixed. I sure would. Especially with an enthusiastic builder. You're bound to learn. This sort of thing can be very hard to troubleshoot as a novice, or in our case from a remote perspective, but a tech with the amp on a bench should be able to do it pretty easily. It'll cost a little but the learning experience will be invaluable. It's not at all uncommon for a novice to build an amp and then require a tech to troubleshoot it. It happens all the time. It does suck out a little of the savings, but that's not the point. The overall experience will get you closer to being able to build, tweak and maintain/repair your own amps. PERSONAL CONTROL OVER YOUR TONE!!! Nothing like it. If you're actually interested in becoming THAT guy it won't seem like wasted money. More like a first person lesson. I did it with Dan Torres when he was still working out of his home!!! He gets a little rough press here and there but he was one of the first players in the game and VERY enthusiastic. Combined with his experience that counts for a lot. It was a good place to start. I hope you can find a tech that actually knows vintage guitar amp circuits and wants to share. It'll be great."Take two placebos, works twice as well." Enzo
Go over the voltages one more time. If pin 1 of the 12AX7 is higher than F3, that means current is flowing the wrong way (or there is a measurement or wiring error). Set your meter to AC volts. Measure from pin 9 to pin 4 of the 12AX7. Make sure you are touching the probe to the socket pin, not the wire soldered to it. Remove the tube from the socket and inspect the socket. Do the contacts look bent or discolored?
You should be able to see two glowing filaments inside the 12AX7. Do they look equal in brightness?
The voltages on both power tubes should be the same. Check again, no typos.
Unplug the speaker. Measure the resistance across the speaker terminals. It should be about 6 ohms. Now plug the speaker in. The resistance across the speaker should now measure very low, one ohm or so depending on you meter. Now unsolder one of the wires from the speaker jack that go to the output transformer. The resistance measured across the terminals of the speaker should go back up to 6 ohms. Now measure the resistance from the unsoldered output transformer wire to the terminal where you undoldered the wire, it should be 6 ohms. This checks that there is no short at the speaker jacks.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by g-one View PostTry it. Meter set to ohms, one probe at each end of the cap. (the cap that goes to pin3 of the 12AX7)Originally posted by JohnRose81 View PostPut the speaker in. Now it reads 155.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
How would I measure from pin 9-4? Am I measuring AC or DC?Originally posted by loudthud View PostSet your meter to AC volts. Measure from pin 9 to pin 4 of the 12AX7. Make sure you are touching the probe to the socket pin, not the wire soldered to it.
How would I measure the resistance across the speaker terminals?
Set the meter to measure Ohms. If the meter has more than one range, use the lowest range, usually 2K. As a test, touch the probes together to verify you get a low reading below 1 ohm. The way your meter works, the resistance of the probes and interconnecting wires are added to any reading you take. The speaker has two terminals. Touch one probe to one of the terminals and the other probe to the other terminal.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
