The IT manager at work built himself a Ceriatone Yeti 50.
When he tried to power it up it did'nt work and the output tubes red plated so he sent it home with me to do the set to work.
There was absolutely no way I was going to fault find it and set to work without a schematic - so trace was done, see attached.
The main problem was the layout diagram, to which it was built, shows the output tranny primary leads swapped from what they need to be, so it oscillated.
Also found several wiring ommisions but no actual wiring errors from his build.
All running now and he is happy.
I put the voltage readings I got onto the schematic trace for future reference.
Cheers,
Ian
Cheers,
Ian
