Just wondering. Although it is not marked on the classic fender 5E3 schematic, in is my understanding that the coupling cap between the second gain stage and the phase inverter is .02uf. Every other coupling cap in he 5E3 is .1uf. Why is this one not .1uf as well?
Why .02 between second gain and PI
Hi Atmars - yep 0.02uF - you'll see it on the 5E3 layout diagram.
I reckon 0.1uF would make the signal too flabby there, but try it if you like.
Actually as an afterthought, I built on recently whereby I used 22nF (mustard caps) on both coupling caps after the first stage and on the coupling cap into the PI as well. It sounds great.Last edited by tubeswell; 01-10-2009, 05:57 AM.Building a better world (one tube amp at a time)
I suppose that there could be too much bass for that stage to handle and causing blocking distortion?
I know that Aiken has a paper on the LTP and using a low value cap just before the PI to prevent blocking dist. Not sure if it would be an issue with the split load PI.Clyde
0.02 is stock and does work pretty well
like the input on LTPIs the input-impedance on that point is higher than the 1M resistor because of "boot-trapping". You can even try using a lower value coupling-cap on that point (let's say 0.002-0.01) to prevend some farting low-end but most of the time changing the other coupling-caps to lower value ones is the way to go.
Are you talking about the coupling caps from the 12AY7 and the caps from lug 6 and 8 off of the 12AX7?
I might try this too. What guitar do you frequently use with the amp?
Originally posted by tubeswell View PostActually as an afterthought, I built on recently whereby I used 22nF (mustard caps) on both coupling caps after the first stage and on the coupling cap into the PI as well. It sounds great.
Originally posted by tele-tubby View PostAre you talking about the coupling caps from the 12AY7 and the caps from lug 6 and 8 off of the 12AX7?
For the ones off pin 6 and 8 of the 12AX7 I just used the stock .1uFBuilding a better world (one tube amp at a time)
