Hey, let's have a better look at those speaker jacks... something doesn't look quite right.
First Amp Build.. 5e3
Originally posted by Bruce / Mission Amps View PostWhere is that red/yellow wire going in the picture of the eyelet board? It should be connected right to ground or the negative lead of the first main filter cap.
All those voltages look OK, relative to each other, but the actual plate voltages are a little high... that would not make the amp quieter.
That is a Russian GZ30 type tube and the only ones I can find anymore that are close to 5Y3GT but not an over priced SOVTEK 5Y3GT which is also a 5U4C.
It is not a bridge rectifier... just a simple full wave rectifier.
You can lower the B+ voltages a bit with some 5 watt zener diodes but this is not the problem you are running into.
Shoot me/us some other pictures and email them or post them here, and I'm sure we'll spot what is/are the issue(s).
Also, as mentioned in our private email messages, try to measure some of the AC signal voltages coming out of the coupling caps while strumming too. It could be that there is not enough drive from the preamp to turn the power tubes on all the way, due to a bad part or a very simple miswiring.
I have a ton of pics I'll post tomorrow.. can't really post them from my phone very well.
I measured voltages in 2 of the 3 places you mentioned but wasn't sure where I was measuring for one of them.. Everything I read that I thought could be it was basically 0. I'm having some issues with this meter though--going to get another one tomorrow that I can trust a little more.
Originally posted by Bruce / Mission Amps View PostHey, let's have a better look at those speaker jacks... something doesn't look quite right.
Originally posted by Caparris View Post...Blue cloth covered wire ran between the two center lugs may be what you are seeing that looks funny..? I think in my email to you I said green cloth wire but it looks like blue in the picture....
It looks to me like that Blue (in the picture) cloth covered wire is connecting the ground pin of the left jack to the hot pin of the right jack. If this is true then your output is shorted. The green OT wire is also connected to ground.
Suggest you recheck all the OT secondary wiring.
Tom
Originally posted by Tom Phillips View PostI agree with Bruce that the output jack wiring appears suspicious.
Tom
Yeah, you guys are right. I wired the output jacks as if they were mirror images of one another. Obviously that isn't the case. So I had the 4ohm jack basically backwards of how it should have been.
I am almost certain I disconnected the 4 ohm wiring altogether though after I had issues just as I was trying to elminate possiblities. I will check when I get off work and rewire accordingly.
Is it likely this fried anything?
Originally posted by Caparris View Post...Is it likely this fried anything?
Good Luck,
Tom
Originally posted by Tom Phillips View PostFor an amp like yours there is a very good chance that everything will be OK after you correct the wiring. No sense in worrying now. Just proceed with the fix and give it a sound check and let us know how the amp sounds. Most likely it will jump to life.
Good Luck,
Tom
I was getting pretty discouraged. I really hope this is it.. Even if I have to replace some parts, at least the (or a) problem has been identified so I have some direction now.
