finished building my 53e but only get humm help please
  • finished building my 53e but only get humm help please
    I finished building my 5e3 clone the pilot light turns on and so do the heaters in the tubes, then when I turn the standby switch off only hum, I've plugged a guitar in and no sound at all just hum... I think maybe the jacks are wrong... any help?
    Can anyone give a good example of how to wire the jacks
    What layout or schematic did you use? The weber layout is about as clear as it gets as to where the wires on the jacks go,https://weberspeakerscom.secure.poww...5e3_layout.jpg
    see if you can post a picture. You should probably go over the layout very carefully double checking each connection & component value.
    JOE
    Resistors not Transistors !
      thanks joe I've sorted the problem out, I am using the weber layout though
        i'm having the same problem, how did you fix it? help. please.
        Thanks
        Joe
