Just finished my very first 5E3 build. Powered it up, and it worked well except that when plugged into either channel, with all knobs at zero, I get sound when I play my guitar. As I turn up the volume knob of the channel I am playing, it stays at the same volume (somewhat low and muted, very thin and hollow, but definitely not what it should be) until about 2, then it kicks in fairly loud and sounds how I'd expect. Something is obviously amiss here, though, because with all knobs set to zero, I should not hear my guitar, right?
I read another post here about crosstalk or leakage (http://music-electronics-forum.com/s...ead.php?t=5657), which sounded a bit like what I was experiencing. Is that what's happening here? Bad pots? I did ground the pots to themselves by bending the tab onto the body and soldering it, and that was mentioned in the other post as a culprit. Could a bad solder joint cause this? I have triple checked the wiring of the tone stack and it's all right. Anyone have any ideas?
