is this the layout you were using??
Novice 5e3 Build Pops fuse & has low hum/no output
Yes, that is the exact diagram I was using, which ones are the preamp electrolytic caps? I am sitting in class right now, I should be back at my dorm in a few hours though and I will check the preamp tube pins 4, 5, and 9 along with the preamp electrolytic caps, if you can tell me which ones the are ^.^
Okay, so I got the amp to "work". I reversed the direction of the preamp electrolytic caps and attached the jumpers on pins 2&7 between the 6v6's that I forgot. And now with the amp working and creating sound, a new problem has arisen; the volume controls dont seem to do shit, and actually the amp has a cranked tweed tone constantly. Whenever I hit a chord hard, the amps volume actually decreases, kind of a reverse volume swell effect. wtf? any ideas now? lol
Mission 5e3 Build - Crackle and voume swell?
Okay, so here is the latest pic of my chassis. so far so good, im hoping...
along with this new problem, input 2 of the bright channel doesnt work even though i get a clean connection off the jack to the 68k resistors (multimeter tested)... defective jack maybe? it looks fine.
LOL I just accidentally cracked one of my 6v6's while it was out of my amp. No more work until tomorrow. I hope someone in town has tubes in stock. well, that gave me a laugh i needed after much frustration.
I did rewire all 4 inputs, added a missing ground jumper from one of the volume knobs to an input ground, and I'll just have to see what that did to help.
Originally posted by Apocrathia View PostLOL I just accidentally cracked one of my 6v6's while it was out of my amp. No more work until tomorrow. I hope someone in town has tubes in stock. well, that gave me a laugh i needed after much frustration.
From your pictures it is hard to tell but I think the input jacks might be wired wrong.
Look carefully at the included input jack artwork that came with the kit in the large documents envelope.
Those switching input jacks seem to baffle new builders.
Look at the attached photo here (down below) and make sure they are wired this way...
An ungrounded volume pot (especially if it is the normal channel volume pot in this layout) means the amp will be running wide open, full volume with no attenuation.
Please make sure your three unused high voltage secondary wires are cut clean with no bare wiring showing and are not all bundled together in one piece of shrink tubing.
I can't see where you connected the power cord's neutral whit wire to the PTs neutral wire.
Also make sure your two 220K grid load resistors for the 6V6s are grounded at their junction.
All the power tubes are "preselected" and are middle ranged as far as their natural resting idle current wants.
For a quick test you can run that amp on one power tube for a couple mins... I know it sounds bad and will be hummy but you'll be able to tell if you are making progress.
Also, the 5Y3GT is a NOS one but I always check them when I buy them and give them a 10min burn in to be sure I didn't get stuck with a dud.
I think you are getting very close to being all figured out.
Here are the two pics I rewired my input jacks after.
There was a ground missing on one of my volume pots which probably had something to do with the failtone I was getting.
As far as solder joint go, I'm going to have to suck off half of the joints and redo them, I know. I tried to get the most of them as best as I could, but a few of them definitely need to be redone. I will tackle that later today.
Thanks thus far for all of your help. I have to get to class in a few seconds, but I will be going and buying tubes later today and I will get back to everyone with the results.
Originally posted by Bruce / Mission Amps View PostFor a quick test you can run that amp on one power tube for a couple mins... I know it sounds bad and will be hummy but you'll be able to tell if you are making progress.
w00t!
Just got back from my local music store and installed a new matched pair of EH6V6GT's just like i got from bruce (saving the other from the original set as a backup), and everything is WORKING!!!! 0-hum and the tone is awesome! (no tubes running too hot, I am really glad I didn't waste the money to send it back to be fixed (No offense bruce, lol.) and I did it myself, really helped me learn more about this amp. I will post pics later on in a different thread of my new setup.
Thanks to everyone who put in their advice and 2¢. and thanks to Bruce for kicking ass.
It's pretty cool/odd that this amp was finished on Friday the 13th, lol...
