A couple of quick observations. A 27K feedback resistor from the 16 ohm tap? Usually it goes to the 2 ohm tap.
The .02uF cap from plate to cathode of the trem oscillator. Seems kind of high for a tube with a 470K load resistor. Try it, but remove if it won't oscillate.
The reverb arrangement will feedback on itself so you have to limit the amount. There is a Champ (Champ12?) that used the speaker output to drive the reverb and there was a trim pot to limit the reverb. I like the mix resistors at the PI input better. IMHO YMMV
