Post 18 has 750 VAC on the rectifier anodes. Now you have 338 VAC per anode. That is a very significant voltage loss. Did you ever substitute the rectifier? You need to do that and report back.
Your 5 VAC appears to be unchanged from its original 5.2 VAC. But your former 6.5 VAC now seems low at 2.95 VAC to ground. Measure the voltage directly at pins 2 and 7 of the first 6L6 and report back.
Your bias voltage has dropped as well.
What is that current reading across the Standby switch? You have 00.8 A. That is off by ~ a factor of 10 for a nominal current draw. Did you mean 0.08 A? Verify that and report back.
The "before and after standby" voltage checks are often useful in determining if a PT has become lossy or has shorted turns.
If the current draw is indeed 0.08 A (80 mA) at the Standby switch, that rules out any excessive current draw in the circuitry after the Standby switch. Then you have to suspect the PT or rectifier and their associated wiring.
