If your chassis is stainless steel it is. Ally is a bit softer and it is easier to 'dig' the nuts in just by making them good and tight (without stripping them)
Ok so on the 5E3 type chassis that is using the brass ground plate, would one use the star washers between the brass plate and the inside of the chassis??
No washers needed.
You mount the brass plate under the bushings of the Switchcraft jacks and between them and the chrome chassis.
Tighten the bushing nuts hard enough for the jack to "dig" into the brass as you very very slightly twist the jack to get it to "seat" into the brass.
Also, don't forget this tip:
Always solder the ground wires onto the brass plate before mounting this stuff. If you don't do it first and mount the assembly to the chassis, it's a good bet you'll never get the brass and ground wires hot enough to flow solder and that is all there is to it.
All my tweed amp chassis are chrome plated mild steel and all my kits come with a nice brass ground plate.
